Vand amplificator vintage Pioneer A-717
Crează un subiect nou   Răspunde la subiect    Pagina de start a forumului Be loud! Din pasiune pentru sunet -> Amplificatoare 5.1, Receivere
pompiliu_dobrin
Data înscrierii: 31/Oct/2009
Locaţie: Bucuresti
MesajTrimis: Sâm Oct 31, 2009 8:24 pm    Titlul subiectului: Vand amplificator vintage Pioneer A-717 Răspunde cu citat (quote)
Amplificator Pioneer A-717, stare foarte buna, cunoscatorii stiu despre ce este vorba.
Pretul este de 180 euro.
PRETUL ESTE FIX, NU NEGOCIEZ SI NU FAC SCHIMBURI!
P.S. Nu tin aparatul rezervat , nu trimit in tara, predarea se va face personal cu proba la mine sau/si la cumparator!
Multumesc pentru intelegere.
Rating of a mode
Form Stereo Integrated Amplifier
Effective output
(Both channel drive, 20Hz - 20kHz) 100W+100W (0.003%, 8ohm)
120W+120W (0.003%, 6ohm)
150W+150W (0.005%, 4ohm)
Dumping factor (1kHz, 8ohm) 200
Input sensitivity/impedance Phono M 0.2mV/100 ohm
Phono man month: 2.5mV / 50kohm
compact disk, Tuner, Line, Tape:150mV /, 50kohm
Phono maximum permissible input
(THD 0.008%, 1kHz) Phono MC:19mV
Phono MM:200mV
An Output voltage/impedance Tape Rec, ADPT Out:150mV /, 2.2kohm
Frequency characteristic Phono M 20Hz-20kHz??)0.3dB
Phono man month: 20Hz-20kHz??)0.2dB
compact disk, Tuner, Line, and Tape:1Hz-150kHz+0 -3 dB
Tone control (-40dB) Bass: ??)8dB (100Hz)
Treble: ??)8dB (10kHz)
Subsonic Filter 5Hz(12dB/oct)
Loudness contour (-40dB) 100Hz/10kHz(5dB/3dB
S/N
(An IHFA network, a short circuit) Phono MC:71dB(0.25mV)
Phono MM:89dB(2.5mV
compact disk, Tuner, Line, DAT/Tape1, Tape2:108dB
Speaker load impedance 4ohm-16ohm
Supply voltage AC100V, 50Hz/60Hz
AC outlet Power-switch interlock: Two lines (200W)
Power-switch un-interlocking.: One line (100W)
Power consumption (Electrical Appliance and Material Control Law) 270W
Dimensions Width 420x height 162x depth of 435mm
Weight 19.6kg
friday
Data înscrierii: 05/Aug/2011
MesajTrimis: Vin Aug 05, 2011 11:23 pm    Titlul subiectului: Răspunde cu citat (quote)
v-am lasat un mesaj privat.sa-l cititi
Afişează mesajele pentru a le previzualiza:
Crează un subiect nou   Răspunde la subiect    Pagina de start a forumului Be loud! Din pasiune pentru sunet -> Amplificatoare 5.1, Receivere Ora este GMT + 3 ore
Nu puteţi crea un subiect nou în acest forum
Nu puteţi răspunde în subiectele acestui forum
Nu puteţi modifica mesajele proprii din acest forum
Nu puteţi şterge mesajele proprii din acest forum
Nu puteţi vota în chestionarele din acest forum
