Vand amplificator vintage Pioneer A-717
Crează un subiect nou   Răspunde la subiect    Pagina de start a forumului Be loud! Din pasiune pentru sunet -> Amplificatoare 5.1, Receivere
pompiliu_dobrin
Data înscrierii: 31/Oct/2009
MesajTrimis: Sâm Oct 31, 2009 8:24 pm    Titlul subiectului: Vand amplificator vintage Pioneer A-717 Răspunde cu citat (quote)
Amplificator Pioneer A-717, stare foarte buna, cunoscatorii stiu despre ce este vorba.
Pretul este de 180 euro.
PRETUL ESTE FIX, NU NEGOCIEZ SI NU FAC SCHIMBURI!
P.S. Nu tin aparatul rezervat , nu trimit in tara, predarea se va face personal cu proba la mine sau/si la cumparator!
Multumesc pentru intelegere.
Rating of a mode
Form Stereo Integrated Amplifier
Effective output
(Both channel drive, 20Hz - 20kHz) 100W+100W (0.003%, 8ohm)
120W+120W (0.003%, 6ohm)
150W+150W (0.005%, 4ohm)
Dumping factor (1kHz, 8ohm) 200
Input sensitivity/impedance Phono M 0.2mV/100 ohm
Phono man month: 2.5mV / 50kohm
compact disk, Tuner, Line, Tape:150mV /, 50kohm
Phono maximum permissible input
(THD 0.008%, 1kHz) Phono MC:19mV
Phono MM:200mV
An Output voltage/impedance Tape Rec, ADPT Out:150mV /, 2.2kohm
Frequency characteristic Phono M 20Hz-20kHz??)0.3dB
Phono man month: 20Hz-20kHz??)0.2dB
compact disk, Tuner, Line, and Tape:1Hz-150kHz+0 -3 dB
Tone control (-40dB) Bass: ??)8dB (100Hz)
Treble: ??)8dB (10kHz)
Subsonic Filter 5Hz(12dB/oct)
Loudness contour (-40dB) 100Hz/10kHz(5dB/3dB
S/N
(An IHFA network, a short circuit) Phono MC:71dB(0.25mV)
Phono MM:89dB(2.5mV
compact disk, Tuner, Line, DAT/Tape1, Tape2:108dB
Speaker load impedance 4ohm-16ohm
Supply voltage AC100V, 50Hz/60Hz
AC outlet Power-switch interlock: Two lines (200W)
Power-switch un-interlocking.: One line (100W)
Power consumption (Electrical Appliance and Material Control Law) 270W
Dimensions Width 420x height 162x depth of 435mm
Weight 19.6kg
friday
Data înscrierii: 05/Aug/2011
MesajTrimis: Vin Aug 05, 2011 11:23 pm    Titlul subiectului: Răspunde cu citat (quote)
v-am lasat un mesaj privat.sa-l cititi
Crează un subiect nou   Răspunde la subiect    Pagina de start a forumului Be loud! Din pasiune pentru sunet -> Amplificatoare 5.1, Receivere Ora este GMT + 3 ore
