adicristi51
Data înscrierii: 09/Iun/2010 Mesaje: 21
Trimis: Mar Aug 10, 2010 9:37 am Titlul subiectului: Amplif Rockford Fosgate 4x65w Rms Model 501x |
65 watts RMS x 4 at 4 ohms
125 watts RMS x 4 at 2 ohms
250 watts RMS x 2 at 4 ohms in bridged mode
2-, 3-, or 4-channel output
4-ohm stable in bridged mode
Tri-way capable (Tri-Way crossover required)
requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
front and rear switchable high-pass (120 Hz, 12 dB/octave) and low-pass (80 Hz, 12 dB/octave) crossovers
MOSFET power supply and output devices
Maximum Efficiency Heat Sink Application (MEHSA) mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
NOMAD — advanced protection circuitry for "intelligent" shutdown protection
speaker- and preamp-level inputs
preamp outputs
12-1/16"W x 2-3/8"H x 9-7/8"D
PRET 250
TEL 0723 583 411 |
Velin
Data înscrierii: 28/Apr/2010 Mesaje: 33 Locaţie: BUCURESTI
Trimis: Vin Aug 13, 2010 11:46 am Titlul subiectului: |
Salut...ceva poze reale?....pretu este fix? |
leone Priceput
Data înscrierii: 27/Feb/2007 Mesaje: 605 Locaţie: Brasov
Trimis: Vin Aug 13, 2010 4:01 pm Titlul subiectului: |
Euro sau Roni  |
Nu puteţi crea un subiect nou în acest forum Nu puteţi răspunde în subiectele acestui forum Nu puteţi modifica mesajele proprii din acest forum Nu puteţi şterge mesajele proprii din acest forum Nu puteţi vota în chestionarele din acest forum You cannot attach files in this forum You cannot download files in this forum
