Amplif Rockford Fosgate 4x65w Rms Model 501x
adicristi51
Data înscrierii: 09/Iun/2010
MesajTrimis: Mar Aug 10, 2010 9:37 am    Titlul subiectului: Amplif Rockford Fosgate 4x65w Rms Model 501x Răspunde cu citat (quote)
65 watts RMS x 4 at 4 ohms
125 watts RMS x 4 at 2 ohms
250 watts RMS x 2 at 4 ohms in bridged mode
2-, 3-, or 4-channel output
4-ohm stable in bridged mode
Tri-way capable (Tri-Way crossover required)
requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
front and rear switchable high-pass (120 Hz, 12 dB/octave) and low-pass (80 Hz, 12 dB/octave) crossovers
MOSFET power supply and output devices
Maximum Efficiency Heat Sink Application (MEHSA) mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
NOMAD — advanced protection circuitry for "intelligent" shutdown protection
speaker- and preamp-level inputs
preamp outputs
12-1/16"W x 2-3/8"H x 9-7/8"D
PRET 250
TEL 0723 583 411
Velin
Data înscrierii: 28/Apr/2010
Locație: BUCURESTI
MesajTrimis: Vin Aug 13, 2010 11:46 am    Titlul subiectului: Răspunde cu citat (quote)
Salut...ceva poze reale?....pretu este fix?
leone
Data înscrierii: 27/Feb/2007
Locație: Brasov
MesajTrimis: Vin Aug 13, 2010 4:01 pm    Titlul subiectului: Răspunde cu citat (quote)
Euro sau Roni Question
