VAND preamp MINDPRINT EN-VOICE DI-MOD / adv RECORDING device
lime
Data înscrierii: 21/Sep/2012
MesajTrimis: Vin Sep 21, 2012 1:51 pm    Titlul subiectului: VAND preamp MINDPRINT EN-VOICE DI-MOD / adv RECORDING device Răspunde cu citat (quote)
Vand preamp Mindprint envoice di-mod , eq compression etc..(recording device, the creative tool for voice and instruments). Pentru mai multe detalii vizitati siteul producatorului.
Pret 250 euro negociabil.
emil_frk@yahoo.com
The entrance makes the difference
the difference in sound between a project studio
and a top-class studio is mainly by
determining the quality of the existing physical inputs. Only a good input channel is able to
appreciate the quality of up to 32-bit internal resolution -. capture it every detail and the signal so prepare that no nuances are lost , the creative tool for voice and instruments , the En-Voice's Ćž them with the necessary tools at hand to prepare the signal for recording. With quality mic bring you singing or instruments to the correct recording level, with the equalizer you determine the tone. The compressor provides the necessary in the overall mix. With the optional converter module DI-Mod, you get direct access to the digital world.
Input section
through its high-quality Class A mic input,
the instrument and line-input, provides the En-Voice Ćž for optimal sound processing, what ever you connect. The input selector switch enables the flexible use recording and editing without patchbay, with the di-Mod even in a digital environment.
Parametric EQ
The 3x parametric EQ allows you the creative sound shaping. True to
your expectations, you are now able to highlight bands or suppress.
Tube Compressor
The adjustable tube saturation brings the liveliness and warmth to your sound, which lack modern recording equipment can repeatedly hear the compressor provides more details and an assertive sound that blends perfectly into the mix.
Easy integration in analog
and digital environments
with the optional converter module DI-Mod has
the En-Voice Ćž on 24bit S / PDIF inputs and outputs. By automatic sync he is to integrate into an existing digital recording setup
- and thanks to the insert jack can even
run two En-Voice Ćž with a di-Mod.
Features
Mic Preamp with 48V phantom power
Instrument input, line input
Switchable low-cut 50/100 Hz
Fully programmable low / high semiparametric, Mid: 3-parametric EQ
Tube compressor with variable tube saturation
Attack and Release slow / fast switching
switchable low-cut side chain filter, 300 Hz, 6 dB / octave
Balanced Line Out XLR and jack
Optional 24-bit digital inputs
[/URL]
[/URL]
