Kenwood kdc w 7544u usb radio cd
BRares
Data înscrierii: 10/Feb/2014
MesajTrimis: Sâm Mai 19, 2018 9:58 pm    Titlul subiectului: Kenwood kdc w 7544u usb radio cd Răspunde cu citat (quote)
pret 200 lei
tel 0757668190 cu proba in CLUJ
trimit in tara contracost prin fan courier
import germania stare perfecta
se vinde cu sina mufa alimentare nu am rama
Key Features
CD Player with MP3/WMA/AAC decoder built-in
Rear Aux & USB input
Music search + favorite memory function
Variable colour illumination with emotional illumination effect.
5 line, Full dot LCD display
Bluetooth handsfree + audiostreaming with optional KCA-BT200
iPod digital connection with optional KCA-iP101
3 preouts with 4.0V output level
Sound excellence DSP
General Features
DIN Size 1 DIN
Detachable Faceplate Yes
Protection Case For Faceplate Yes, Soft Case
Faceplate Mechanism Full Detachable Faceplate
Disabled System Indicator (DSI) Yes
Security Code Function Yes
Key Illumination Variable
Rotary Encoder & Control Knob Yes
Operation mode 4-Directions + Push
Multi control wheel Yes
Music Search function Yes
Favorite Memory function Yes
Installer Memory Yes
Back-up Memory
Attenuator with Smooth Volume Return Yes
Touch Sensor Tone Yes
Optional IR remote controller Yes
Digital Clock (24H) Yes
All-off Select (20/40/60 minutes) Yes
Built-in Connector Molex 16 pin
ISO connector Yes
Optional Bluetooth unit Yes, KCA-BT200
Display Features
Display Type LCD Display
Display Layout 5 line, Ful dot
Spectrum Analyzer
Dimmer Control OFF/Auto/MNAL1/MNAL2
Display Off Mode Yes
Demo Mode Yes
Special Character Display No
Menu text in selectable language
Cosmetics features
Front/edge Piano black
Dress plate Piano Black
Volume & operation knob or wheel Chrome Plated
Preset key finish Black Injection
Escutcheon finish Piano Black
Triangle Illumination Red
Volume & operation knob illumination Variable
Key illumination variable
Tuner Features
K3I - Clean Reception Tuner Yes
FM Reception Yes
AM (MW/LW) Reception Yes
Presets 24 Presets (18FM / 3LW / 3MW)
Tuning mode
Up/Down Seek/Scan Yes
Automatic Memory Entry (AME) Yes
FM Stereo / Mono Selector Yes
Radio Data System Yes
Radio Text Plus Yes
Enhanced Other Networks Function (EON) Yes
Program Type Function (PTY) Yes
CD Features
CD-R/RW Compatible Yes
MP3 Playback with ID3 Tag Display Yes
WMA (Windows Media Audio) Playback Yes
AAC (Advanced Audio Coding) Playback Yes
Multi-session Disc Playback Yes
CD Text Support Yes
Supreme Yes
D.A.C. processing 24 bit
Random Function
Repeat Function
Scan Function
Kenwood Music Editor Software included Yes
USB Features
USB terminal Yes, Rear
USB Type USB1.1 / USB 2.0
USB extension cable supplied no
MP3 playback with ID3 Tag Display Yes
WMA (Windows Media File) playback Yes
AAC (Advanced Audio Codec) playback Yes
iPod Features
Made for iPod & iPhone * Yes
USB Direct Control with optional KCA-iP101
Music playback Yes
Music library search Yes
Alphabet search Yes
Skip search Yes
Control by hand Yes
Works with iPod Classic *
Works with iPod Video * 5th/6th generation
Works with iPod Touch * 1st/2nd Gen
Works with iPod Nano * 1st/2nd/3rd/4th Gen
Works with iPhone * iPhone, iPhone 3G & iPhone 3GS
Battery charge + power control Yes
* Always update to latest Apple firmware
External Media Control Features
Dual Changer Control (CH1, CH2 & AUX) Yes
CD Text Ready with Compatible KENWOOD Units Yes
Disc & Track Repeat Yes
Disc & Track Scan Yes
Disc & Track Random Play Yes
Direct Access Yes
Bluetooth Handsfree Yes
Bluetooth Audio Streaming Yes
2004 B.M.S. Amplifier Control Yes
iPod Control with KCA-iP500 Yes
AUX RCA Adaptor Yes
Audio Features
Maximum Output Power 50W x 4
MOSFET Power IC Yes
Auxiliary input Yes, rear
Auxiliary Type Mini-jack
Pre-out 3 RCA
Pre-out Output Level 4V
Preout Rear / Subwoofer Switchable Yes
Subwoofer Reference Level Adj. Yes
Built-In Amplifier Cut-Off Yes
Dual-Zone Source & Volume Control Yes
Dual-Zone (FRONT / REAR Switchable) Yes
Source Tone Control & Memory Bass / Mid / Treble
Balance/Fader/Loudness Control Yes
Balance/Fader Control Yes
Bass Boost Circuit
Att.(-20dB) with smooth Volume Return Yes
Sound Excellence DSP Yes
System Q_EX (Preset & Manual Sound Control) Yes
System Q (Preset Sound Control) Yes
Equalizer built-in Yes
Digital Time Aligment (DTA) Yes
System E's (Built-in HPF& LPF) Yes
Game Mode EQ Yes
DSP-Features
5 bands graphical equilazer Yes
Highway sound Yes
Bass Boost Yes
iPod EQ select mode Yes
Supreme Yes
Connectivity
Changer Control (5L-Bus) Yes
External Option Control (5L-Bus) Yes
AUX input (5L-Bus) Yes
iPod I/F Control (5L-Bus) Yes
Bluetooth Control (5L-Bus) Yes
PS Amplifier Control System (5L-Bus) No
B.M.S.Control ('99-'03 Amps) Yes
OEM Wired Remote Control ready Yes
OEM Display Control ready Yes
Power Control (P.CON) wire Yes
External Amplifier Controle Wire Yes
2-way (Tel/Navi) mute wire Yes
Dimmer control wire Yes
Tuner Specifications
FM Frequency Range 87.5MHz ~ 108MHz
FM Frequency Step 50kHz
FM Usable Sensitivity 0.7μV/75ohm (S/N 26dBf)
FM Quieting Sensitivity 1.6μV/75ohm (S/N 46dBf)
FM Frequency Response 30Hz ~ 15kHz (± 3dB)
FM Selectivity(DIN) over 80dB (±400kHz)
FM Stereo Separation (1kHz) 35dB
MW Frequency Range 531kHz ~ 1611kHz (9kHz step)
MW Frequency step 9kHz
MW Usable Sensitivity 25μV
LW Frequency Range 153kHz ~ 281kHz (9kHz step)
LW Usable Sensitivity 45μV
CD Specifications
Laser Diode GaAIAs
Digital Filter(D/A) 8 Times Over Sampling
Digital/Analogue Converter 24 Bit
Spindle Speed 500 ~ 200rpm (CLV: 1 times)
Wow & Flutter Below Measurable Limit
Frequency Response 10Hz ~ 20kHz (±1dB)
Total Harmonic Distortion 0.008% (1kHz)
Signal to Noise Ratio 105dB (1kHz)
Dynamic Range 93dB
MP3 Decoder Compliant with MPEG-1/2 Audio Layer-3
WMA Decoder Compliant with Windows Media Audio
AAC Decoder AAC-LC".m4a" Files
USB Specifications
USB Version compatibility 1.1 / 2.0
File System FAT 16/32
Maximum Supply current 500mA
MP3 Decode Compliant with MPEG-1/2 Audio Layer-3
WMA Decode Compliant with Windows Media Audio
AAC Decode AAC-LC "m4a" Files
Max. nr. of files 65025
Max. nr. of folders 50
Max. nr. of files per folder 255
Max. characters for file & folder name 64
Max. nr. of characters for file names 64
Max. nr. of characters for folder names 64
Max. nr. of characters for MP3 tags 30
Max. nr. of characters for WMA-tags 30
Max. nr. of characters for AAC-tags 30
Audio Specifications
Maximum Power 50W x 4
Output Power (DIN45324,+B=14.4v) 30W x 4
Preout Level 4000mV / 10kOhm,
Preout Impedance ≤ 600Ohm
Speaker Impedance 4Ohm ~ 8Ohm
AUX Frequency Response 20Hz ~ 20kHz (±1dB)
AUX Maximum Input Voltage 1200mV
AUX Input Impedance 100kOhm
General Specifications
Operating voltage 14.4V (11 ~ 16V Allowable)
Maximum Current Consumption 10A
Dime
BRares
MesajTrimis: Mar Mai 22, 2018 7:01 am    Titlul subiectului: oferta Răspunde cu citat (quote)
Pret de vanzare fara negocieri 175 lei si va platiti transportul
