golf mk2
razz
Data înscrierii: 13/Iul/2007
Locaţie: suceava
MesajTrimis: Sâm Oct 31, 2009 12:46 am    Titlul subiectului: golf mk2 Răspunde cu citat (quote)
salutare,
Sa imi prezint si eu pt inceput sistemul. Masina este un golf2 din 91. Din muzica stoc, am mai pastrat tweeterele in rest montat urmatoarele:
*HU-JVC kd-g331
*Fata-componente sistem pe 10cm de la JVC.
*Spate-coaxiale de la LG(numai sa umple golul de acolo)
*Amp-Audio system Mseries-mx 120.2
2-Channel High Power Class-AB amplifier with SMD technology
MOS-FET PWM Power Supply
Stable into 2 ohm stereo per channel and 4 ohm bridged mode
Variable switchable Low Pass Filter from 50 to 300 Hz
Variable switchable High Pass Filter from 25 to 175 Hz
Variable switchable Band Pass Filter from 25 to 175 Hz (HPF) and from 45 to 300 Hz (LPF)
Bass Boost: variable from 0 to 6 dB and from 35 to 90 Hz
Input Sensitivity: variable 200 mV maximum to 8 V minimum
ulti- ay rotection ircuitry: overhead, over ourrent, short circuitry and speaker DC protection
Operating Voltage : DC 10 ~ 16 V power input
Massiv heavy aluminium-heatsink with fan cooling
Wired Remote Controller
*sub- Audio system radion 12 plus(400w)- in incinta bass-relfex(trebuie sa o mochetez)
* baterie de 70 Ah
La partea conectica si curent stau cam prost: cabluri de 10mm, urmeaza un minim 35mm, un alt alternator si un condensator
in configuratia de mai sus, fara cond, cabluri de 10 mm si baterie pe terminate (una de 55Ah), la o masuratoare dB a iesit 135
 Filesize:  526.4 KB
 Viewed:  580 Time(s)
 Filesize:  532.36 KB
 Viewed:  501 Time(s)
 Filesize:  701.6 KB
 Viewed:  499 Time(s)
 Filesize:  365.69 KB
 Viewed:  485 Time(s)
 Filesize:  571.66 KB
 Viewed:  509 Time(s)
 Filesize:  365.09 KB
 Viewed:  490 Time(s)
costy_suceava
Data înscrierii: 15/Oct/2009
Locaţie: suceava
MesajTrimis: Sâm Oct 31, 2009 12:50 am    Titlul subiectului: Răspunde cu citat (quote)
frumos:-p
ugod
Data înscrierii: 30/Aug/2008
Locaţie: Timisoara
MesajTrimis: Sâm Oct 31, 2009 9:21 pm    Titlul subiectului: Răspunde cu citat (quote)
au viatza mea ce-i acolo ...pacat de banii investiti in scule
1 . incinta nu se face din pal cu melamina
2 , pune ceva cabluri mai groase chit ca nu ai incarcare mare
3. fa cumva montajul la amplif in alta parte banketa de g2 e din carton si o sa-ti pice de acolo
razz
Locaţie: suceava
MesajTrimis: Sâm Oct 31, 2009 9:51 pm    Titlul subiectului: Răspunde cu citat (quote)
ms de sfaturi ugod...tiam vazut sistemul pe care il aveai/sau il ai pe club vw.
in legatura cu ce ai zis:
1) la incinta nu am avut de unde face rost de MDF
2) cabluri urmeaza sa iau ceva de un minim 35mm, preferabil un awg 0 de 50.
3)cand pun cablurile noi am sa schimb si placajul din spate, unde vin difuzoarele alea LG, am sa fac ceva din Pal, si am sa prind de el statia.
acum am cablurile prea scurte.
razz
Locaţie: suceava
MesajTrimis: Vin Mar 26, 2010 12:53 pm    Titlul subiectului: Răspunde cu citat (quote)
noutati:
amplificatorul, subwooferul+incinta si cablurile au fost vandute.
fiin foarte multumit de calitatea celor de la audio system am achizitionat:
*componente xion 13 cm de 90w rms (usi fata)
*o rola de alubutyl 500 (10mx 50cm), care sper sa imi ajunga sa insonorizez partial masina.
* pt usile spate am sa montez componente de 13 cm Jvc, care momentan sunt pe fata si suna ok.
pt viitorul apropiat sper sa reusesc sa fac rost de bani de o statie pt difuzoarele usi, apoi pt partea de bass.
http://img93.imageshack.us/i/1005728.jpg/
Si un mic upgrade la masina Very Happy : suspensie reglabila weitec.
costy_suceava
Locaţie: suceava
MesajTrimis: Vin Mar 26, 2010 12:55 pm    Titlul subiectului: Răspunde cu citat (quote)
Smile)) suspensie ....pt drumurile din suceava:))
frumos
Locaţie: galati
MesajTrimis: Vin Mar 26, 2010 7:54 pm    Titlul subiectului: Răspunde cu citat (quote)
ugod ...
ne poti da si noua o explicatie
de ce NU pal melaminat ?!
on ... felicitari pentru ce ai facut acolo ...
calitatile cele mai importante ale unui sistem
sunt cu totul si cu totul altele ... si deabia apoi urmeaza designul
spor in continuare !
YM: shokaliptiku
otzy
Data înscrierii: 14/Feb/2007
Locaţie: timisoara
MesajTrimis: Vin Mar 26, 2010 11:14 pm    Titlul subiectului: Răspunde cu citat (quote)
hmm cat te-o dus suspensia?
razz
Locaţie: suceava
MesajTrimis: Sâm Mar 27, 2010 11:16 am    Titlul subiectului: Răspunde cu citat (quote)
suspensia este 500E, eu am luato cu 400.
In legatura cu mdf/pal - diferente foarte mari la sunet nu cred ca sunt.
Pal'ul nu este chiar asa "rigid", daca pot spune asa, si durata sa de viata in conditii de umezeala este mult mai mica fata de mdf.
Pe tema asta se pot purta multe discutii, si off topic Very Happy
razz
Locaţie: suceava
MesajTrimis: Sâm Iun 19, 2010 9:58 pm    Titlul subiectului: Răspunde cu citat (quote)
Revin si eu cu ceva poze cu suspensia montata + jantele.
Am lucrat mai mult la masina decat la audio. Achizitii recente: stopuri Fk Led, semnalizari In.pro Led, vopsea termorezistenta Foliatec, si altele.
Achizitii pe partea audio destul de putine:
*amplificator Blaupunkt 2x75 W (vechi da bun) pt difuzoarele usilor fata
*a ajuns in final dupa 3 luni de asteptare si rola de insonorizant Very Happy
Urmeaza in viitorul apropiat:
* inele pt difuzoare
* cablu Rca Audio system imbracat in textil.
* cabluri alimentare 35 mm^2
* antifon cauciucat
* pasla pt podeaua masinii
* desfacut toata masina, curatat de rugina, sudat unde este cazul, apoi trec pe izolat si mochetat.
Cam atat imi vine acum in minte.
Sper sa revin cu poze cat mai rapid, poate cu ajutorul lui costy termin mai repede.
costy_suceava
Locaţie: suceava
MesajTrimis: Sâm Iun 19, 2010 10:25 pm    Titlul subiectului: Răspunde cu citat (quote)
ne facem topor Laughing
Locaţie: galati
MesajTrimis: Dum Iun 20, 2010 7:23 am    Titlul subiectului: Răspunde cu citat (quote)
vezi ca ai incurcat putin ordinea cu pal ul si mdf ul ...
este exact invers fata de cum spui tu
daca vrei sa te convingi ... pune o bucata de pal si o bucata de mdf
intr-o caldare plina de apa
dupa o zi de "macerat" ai sa vezi ca mdf ul sa umflat 1mm
iar pal ul "s-a dublat"
YM: shokaliptiku
razz
Locaţie: suceava
MesajTrimis: Dum Iun 20, 2010 10:34 am    Titlul subiectului: Răspunde cu citat (quote)
razz a scris:
Eu cred ca am zis bine, poate dormeai tu shoka, luand in calcul ora la care ai scris Very Happy.
Locaţie: galati
MesajTrimis: Vin Iun 25, 2010 9:06 am    Titlul subiectului: Răspunde cu citat (quote)
hai ca tiai editat postul dupa ce am postat eu
las ca stiu
YM: shokaliptiku
costy_suceava
Locaţie: suceava
MesajTrimis: Vin Iun 25, 2010 10:31 am    Titlul subiectului: Răspunde cu citat (quote)
defapt e cum am zis eu Very Happy Very Happy Very Happy "ne facem topor"
Afişează mesajele pentru a le previzualiza:
Pagina 1 din 3
Nu puteţi crea un subiect nou în acest forum
Nu puteţi răspunde în subiectele acestui forum
Nu puteţi modifica mesajele proprii din acest forum
Nu puteţi şterge mesajele proprii din acest forum
Nu puteţi vota în chestionarele din acest forum
